Question about iPad w/USB-C Flash Drive
I’m going to be picking up an iPad Air 4th gen and would like to connect a USB-C flash drive to store movies, etc. to have show up in Infuse and stream directly from the drive. Can Infuse “index” (get the metadata, etc.) for files on a flash drive without needing to move the files into the Infuse storage directly on the iPad?
Thanks!
I have not specifically tried it, however, USB drives are accessible via the Files app. One of the Infuse sources you can add, is anything in Files. So, seems like it should definitely work, anything Files can access, Infuse should be able to.
Yes, a USB-C drive can be added as a source by using the ‘Via External Folders’ option in Infuse > Settings > Add Files.
