Qnap and streaming
When I connect I’m able to see the files in one folder with 4 folders with movies. But when I go to the folder with 96 folders with movies, nothing shows up. Both are under the same share.
Have you entered a username and password to connect? If not, Infuse will connect as a guest which may limit the files that are available to stream.
I have, that the reason I also can get access to the first folder.
Is there anything you can think of, permission-wise, that might be different about the folder that isn’t showing up?
No and it works on the Apple TV 2
