Hello
I buy Infuse 2 Pro for iPhone4, it is necessary that I buy again for my iPad4?
Thank you in advance
Hello
Infuse Pro is a one-time purchase that can be used on multiple devices.
Just tap the Restore button on the second device to enable Infuse Pro without paying again.
Thank you for the reply ... I followed your advice and I get the following messages!
Purchase
Purchases from an app are not allowed.
then
Itunes Store connection not possible
A special procedure?
Thank you for your help
It's OK the problem was restrictions!
"Settings" then "Restrictions" then "Enable Restrictions" and uncheck "Integrated purchase" option
Thank you anyway
Bye
