Suggestion: Having “metadata” option per each library when setting them up. For TV Shows and Movies, I like having Infuse do online metadata/scraping. However, if I am setting up a personal video folder (not TV/Movies), I want no metadata to be pulled. For instance, I am trying a workaround for movie/tv show extras to be separated out from the movie or TV library. You can go in and manually change to “local metadata” but would prefer it be easier/automatic.
You can set your entire personal folder to “local” and that would do what you’re looking for.
