Hello! Minor bug that only exists if you search for a movie (not if you play it directly from the main screen). The Pin is asked when you trigger Siri while watching a movie and have Parental Controls enabled.
To reproduce it:
- Make sure Parental Controls are enabled (so a Pin is required to watch a movie)
- Search for a move using the Search function
- Start watching
- Use the Siri button for a task (e.g., switch off lights), the Pin will be requested.
My configuration is using Jellyfin, with the Library being disabled (so direct access), if that helps. Happy to test more if you think it is needed.
Thank you
