Inh have an issue, the progress bar on posters is not correct, for example I finished series the pitt but you can see that the progress bar still there
It is happening with all series, when you enter to the series there is no resume or in another case resume will be at 1/3 progress when progress bar might be at 2/3.
I checked plex and there is no issue on its side. What am I missing, or what should I do?
