Problems with subtitles
I have a Emby and Plex server. Sins Infuse 8.5.8 I see my subtitles on the left side in the middle of the screen. Most of the time if I stop the stream and start it again the problem for this episode is fixed. It not happens al the time
I send a report a problem via Infuse more than a week ago. Would be nice if someone can look into it.
Try this first
  1. Open the episode where the subtitles appear on the left.
  2. If restarting playback fixes it, note whether the same subtitle file causes the problem again.
  3. If it happens consistently with that episode, try a different subtitle track. If that fixes it, the subtitle file or its formatting may be responsible.
Thanks for your response. For some unknown reason, my NAS was completely empty last week—no idea why. Afterward, I re-downloaded all the TV series and kept the subtitle files separate. Before the NAS was wiped, I had processed everything using MKVToolNix. For the series that was causing issues, I used MKVToolNix to embed the SRT file directly into the MKV container, and now it plays correctly. I’m hoping that was the cause of the problem. I have no idea why it behaves this way.
(i used google translate)
Problem still happens when I use my emby and Plex server. It is not all the time.
I’m not so long on apple and infuse. But a few updates ago, everything was playing perfectly. I updated to the latest version.
I had send a report via Infuse on 18 oktober with nr: KCP2W so a little help from the dev would be nice.
Edit: it only happens on apple tv
@james Do you have any idea how to fix this? It’s not happening all the time, but it is always the same episode if I test. I can provide you the media if you want? It only happens on the apple tv.
I’m Dutch, So, I hope you understand what I’m typing. Regards.
I also use external .srt files and saw this happen on one occasion
A restart of both the Emby server and the Apple TV fixed the problem you describe for me.
Thank you for your reply.
I already tried that, but the problem is still there.
I bought the lifetime subscription.
More than 2 weeks a make a report via Infuse but still no respons.
Only thing I see in release notes a few time that subtitles are fixed. But that’s not true.
Hi everyone,
I wanted to chime in because I am experiencing the exact same issue on my Apple TV. This happens specifically with Dutch subtitles across all movies and TV shows, regardless of the file type.
Like some others mentioned, the only temporary workaround I’ve found is switching the subtitle language back and forth; this forces the stream to reload and snaps the subtitle position back to the bottom of the screen. However, having to do this manually every single time is quite frustrating.
I also bought the lifetime subscription and love the app overall. Hopefully, this extra confirmation helps the team track it down quickly.
@michaeldecharon Thank you for the extra info about Dutch subtitles.
You’re very welcome! Hopefully, having this extra detail about Dutch subtitles helps pin down what’s causing the issue. Thanks for raising it on the forum as well—let’s hope for a fix soon!
Does the fix include the issue with the subtitles showing up in the middle of the screen?
Right now, it only goes back to normal if I select the subtitle file again.
Hier is een nieuw bericht voor op het forum waarin je aangeeft dat het probleem zich bij alle talen voordoet, en niet alleen bij het Nederlands:
Hi everyone,
After looking into this further, I wanted to update that this issue actually occurs with other languages as well, not just Dutch. It seems to happen regardless of which subtitle language is selected across movies and TV shows.
The temporary workaround of switching languages back and forth still forces the stream to reload and fixes the position temporarily, but the bug definitely affects subtitles broadly. Hopefully, this extra context helps the developers track down the root cause!
Someone from support has send me an email a few days ago. I have send him a new diagnostic report via Infuse app. After that I haven’t heard anything yet. I’m hoping they are working on a solution.
This looks like you have Closed Captions rather than Subtitles.
Closed Captions include positioning information to place the subs closer to the speaker.
If not CC then perhaps the subs contain position information (tags like {\an4} which will move the subtitles to the middle at the left).
Are the subs just plain text with a .srt extension? Maybe post an extract here.
A subtitle that always has this problem begins with. If i stop the epsisode and start is again the problem is gone. So it is not all the time it happens. and yes they all are .srt.
1
00:00:05,468 → 00:00:06,501
Vrij ver van New York.
2
00:00:06,502 → 00:00:08,536
Mijn kind is gisteravond
gewond geraakt bij een brand.
3
00:00:08,537 → 00:00:09,768
Mijn broer… hij was bij hem.
4
00:00:12,343 → 00:00:13,706
Ik wil je officieel maken.
5
00:00:13,707 → 00:00:15,576
Bij jou is het beter met
de borderline-stoornis.
6
00:00:15,577 → 00:00:17,149
Wat? Denk je dat je het
■■■■ bijhouden, Brooklyn?
7
00:00:17,150 → 00:00:19,514
Ik weet niet zeker of
ik je kan bijhouden,
8
00:00:19,515 → 00:00:21,054
Beantown, maar ik
zou het zeker proberen.
Edit: Aha i know know why there is a ■■■■. The word in dutch is a swear word in english. It is the englisch translation from can.
I can’t see anything weird there - it’s just a normal .srt subtitle file.
Although all the “→” should be "-->", maybe that was a copy/paste issue.
Very strange that the positioning is going wrong though.
