Good day I have installed 2.0 pro
When I finished my series I want delete the files of subtitles ( .srt ) that I have added manually previously but I cann´t do it
any suggestions about it ?
thank you
thank you
This can be done through iTunes, as the SRT files will be listed in the Infuse Documents section.
More info here. http://support.firecore.com/entries/23695427-Adding-Videos
Thanks, but in section “Documents infuse” in Itunes I can add .srt files manually but I cann´t delete them
Hmm, are you seeing the srt files listed there, or are they not even visible?
Yes I can see srt files there but I can add them only but I cann´t delete them
Ah, ok.
It’s not very intuitive, but to delete files through Documents list you just need to highlight the files(s) and tap the delete or backspace button to delete them.
Thanks by your help
I apologise for my ignorance
No worries at all.
