Problems with new update
I did the Apple TV update 2.3 and the atv Flash update 3.4.1
Went into the Boxee updated - did that along with the XBMC/Boxee Launcher… but now all I get is a blank screen when I choose Boxee (it worked fine prior to this update!)
Any work arounds? Anyone else having the same problem? Any ideas? HELP!!!
You are not the only one. First be sure you have the newest Launcher and Applications and if that does not fix the problems, you can read about it here:
http://blog.boxee.tv/2008/11/23/boxee-on-apple-tv-23/
or
http://forum.boxee.tv/
Of course reading the entire blog just in case there is an update wouldn’t hurt either.
