problems transferring files
I am trying to transfer a movie to the AppleTV for the first time. I have my AppleTv mounted on the finder and inside it a folder called Movies. I am trying to transfer a movie ****.avi and I got the message “Can’t transfer because “Movies” can’t be modified” What should I do? Thank you very much.
Open Terminal and try:
ssh -1 frontrow@appletv.local
Enter frontrow as the password
sudo chmod -R 775 Movies
If not, you could always SFTP in with cyberduck!
Permission are changable from there (cmd+i)
