Problems Jailbreak
Hello!!. I have this problem:The programa(s) listed below may prevent Seas0nPass for running correctly . Please close these programa(s) before continuing . 1 Kaerpesky internet .
Thanks!!
Where is your problem? Disable Kasperski Internet Security, which probably blocks Seasonpass, and start again.
Seasonpass starts fine it won’t download the patched ipsw.
On my pc also,program runs fine but it won’t download the patched ipsw.No connection to servers.
Problem is solved in another thread!
