Problem with sharing between INFUSE and my MacBook
I’ve been trying to create a share between my MacBook Pro and Infuse…I enter my username and password and all I’m getting is a message that says “Your username and password combination isn’t right. Please try again”
But I’m certain that the username and password are correct…I’m entering the username and password for logging into my profile on my MacBook - isn’t that correct? Or should I be entering another username and password
I’m baffled and have no ideas - I’m able to set up shares with PLEX and my Airport Extreme with no problems but not my MacBook…does anyone have any ideas…
You may check to ensure SMB with Windows File Sharing is enabled on your Mac. This is required in order for 3rd party apps to stream from a Mac.
A bit more info on doing this can be found near the end of this guide. Streaming From a Mac, PC, or NAS – Firecore
Thank-you James…problem solved…much appreciated
