Problem with season pass ???
I am having problems with my atv2
. It locked up on the home screen with no movement from the curser, after trying all the usual things , like a fool I reset it using iTunes, the unit worked fine in standard form . Now when try to jailbreak it using seasonpass, as soon as I try to download the Ipswich 5.210b144b, seasonpass says waiting for the Apple TV please connect using USB to continue ( this didn’t happen until the end of the process when I last did it ?)
Then I get seasonpass has detected critical error(s) and cannot continue please ensure no conflicting software is running and try again
Please help, I am a little rusty at this as the atv has been running great for months without a problem .
I have same problem also if i want to update fom itunes i got message 1604
I fix mine today with snowbreeze and tinyumbrella. if you want i can explain . now its working good and latest version
hi im getting the same error.im trying to jailbreak my apple tv 2 so i can download nitotv and xbmc - but when i rung seaonpass its asking me to connect usb straight away and then i get critical error - can you tell me how you fixed this . im using windows seven ?
squig007
I;m having the same issues. Can’t create ipsw.  erdenur can you please explain what you did to get around this when you get a moment. Thanks.
Hi cayenne my name is Ercan , I work on it about 2 days and i got all messages like 3194.1656 … etc. Ok i shortly expalin how i did . First clear your desktop if you downloades any ipsw and any other
1- Download latest version of Snowbreeze-- sn0wbreeze-v2.9.13
2- Download latest version fo I faith v1.5.6
3- Download latest Tinyumbrealla.
Step one- connect your apple tv2 your pc and start with ifaith and download SHSH what version you want to downgrade I did with  000003EA4D02BDCC_5.2-10B144b_cydia.shsh  and placed easy acces i mean you know where you downloaded.
Step two is start snowbreeze and let it download 5.2-10B144b.ipsw (Not if you already downloaded this version it gaves me error too) When finish show snowbreeze your shsh where to downloaded and click next . When its finish dont do anything else or remove your apple tv. Make sure stay connected .
Step three is start tinyumbrella left side you will see your apple id or some number click that number and click exit recovery .
Thats all connect your apple tv2 to your tv and turn it on . You will see nito tv enter and click xbmc appletv2 install. First you might not see xbmc but dont worry it will come if you restart apple tv2. Then you know what to do you can install any addons you want. Sorry my english if i make mistake and good luck
Ercan
Here is the file shsh from cydia
Still getting the same error. The problem I think I seem to be having is with Tinyumbrella. Can’t seem to figure out what i’m doing wrong. Thanks for all your help btw.
