Problem with metaData Only With "One piece" mange Tv show
Hi evertything it’s perfect with out one tvshow
One piece
800 episodes Tv show … ( TVDB no problem )
but it doesn’t found metadata ( all advice is for Movie not for Tvshow)
my tree
One Piece
Saison 01
One Piece - 01 - Je suis Luffy ! Celui qui deviendra Roi des pirates !.mp4
One Piece - 02 - Le grand manieur de sabre ! Roronoa Zoro, chasseur de pirates !.mp4
Saison 02
Saison 03
Any solution ??? When i Try to édit I see many One piece movie file but no One piece tv show . I can add date ? The link from tvdb is http://thetvdb.com/?tab=series&id=81797
Hi !
Try to rename your files like this : One.Piece.S01E01.mp4
Maybe it will work :wink:
PS: to rename your 800 files you can use free softwares to automate the process.
You need season and episode number on each episode (like this: ‘One Piece - S01E01 - Je suis Luffy…’) - and ‘Saison 01’ should probably be changed to ‘Season 01’, but that’s just a guess…
Thanks  i have already do :) thanks thanks but à thing Frenche name form episode cause multiple problem ( accent or l' ê éè à ù â etc .. )
tell me if that name is correct =
"One Piece - S01E23"
Ony that it's ok for infus found all name and episode etc .. ?
Yes, I think it's ok for Infuse. :)
No i'm try
One Piece_S02E62
infuse does'nt recognize the summary of the episode tittle ... i see Only 62.one piece
In m'y case, I don't leave blank in name  files for series.
That's why I name my files like this : One.piece.S01E01.mp4
I'll try but doesn't Work
infuse found épisode
but i have no summary small thumb etc
The season 2 doesn’t have 62 episodes: http://thetvdb.com/?tab=season&seriesid=81797&seasonid=31895&lid=17
You can use an app like FileBot (http://www.filebot.net) to rename all of your files with the correct SxxEyy.
For the good rename for exemple for the 9th episodes …
Normal is EP09
but if it’s season 2. the good name are S02E01 for the episode 9 i’ll must start to 1 each season or if i rename S02E09 it’s ok ?
The first one.
You should use the same episode number used by thetvdb.
For example, this is the directory structure that I’ve for Dragon Ball Super:
./Stagione 1/Dragon Ball Super S01E14.mp4
./Stagione 1/Dragon Ball Super S01E15.mp4
./Stagione 1/Dragon Ball Super S01E16.mkv
./Stagione 1/Dragon Ball Super S01E17.mkv
./Stagione 1/Dragon Ball Super S01E18.mkv
./Stagione 2/Dragon Ball Super S02E01.mkv
./Stagione 2/Dragon Ball Super S02E02.mp4
./Stagione 2/Dragon Ball Super S02E03.mkv
./Stagione 2/Dragon Ball Super S02E04.mkv
./Stagione 2/Dragon Ball Super S02E05.mkv
./Stagione 2/Dragon Ball Super S02E06.mkv
./Stagione 2/Dragon Ball Super S02E07.mp4
./Stagione 2/Dragon Ball Super S02E08.mp4
./Stagione 2/Dragon Ball Super S02E09.mp4
./Stagione 3/Dragon Ball Super S03E01.mp4
Hi.
I take a lot of time to add correct informations to my shows (particulary animes). Worth it.
For One Piece I do this with folder and subfolders :
One Piece > Saison 1 > One Piece S01E01
(Eventually the name of the episode, but not necessary).
Here’s an example
