Problem with Metadata of Anime "K"
so i have here some files saved on a server.
When i check the Metadata im unable to find here the Anime “K” even when i search for it
When i go on the website themoviedb I find it immediately
any option to improve it on infuse to find it here aswell?
Just tested this and it worked perfect. If you name the files like this and use this directory structure it’s handled by Infuse with no problems.
Im confused why u add them to 3 seasons ?
Its just one season, as the second season is called complete different in the name
And no 3. total
You’ll need to follow the season structure that TMDB does. They’re pretty strict on making them correct.
Again, by naming them as I gave in the example with the year added to the series name both in the file names as well as the directory names along with the S0xE0x for each will give you the correct metadata from TMDB.
The third season was just an example of the structure and naming, not saying there’s 3 seasons.
Don’t forget they also have Season 0 for specials.
All right
Thanks a lot
Just for interesting, without renaming them
Normally I can change the metadata in infuse, but not here.
Is it because the name is to short ? Or is there any chance to find it with meta change ?
