Problem with indexing quality
Now and then certain movies won’t update their info. A movie would for example say 720p 2 chanmel AAC but then it would even say that after updating the file to an uhd remux. I can’t get it to display the correct quality once that happens.
The file specs will be cached in Infuse for performance/efficiency reasons.
If you swap out a lower res video for a higher res version, you can simply use the ‘Edit’ option, reselect the correct title, and the specs will be updated.
Ok excellent. Thank you.
