Good morning!
Since the last week I’ve been sufering a problem loading covers.
Don’t know why but some movies appears with the blueray case cover instead of the cover.
Is there any problem again with themoviedb or some server related problem?
Good morning!
By chance, do you have the ‘Embedded Metadata’ option enabled in Infuse > Settings?
If so, disabling this, and using the Edit option on the affected titles should allow you to get the regular artwork from TMDb.
Problem solved. Thanks so much.
