Problem with Band Of Brothers metadata
OK Thanks
There is a tv show Band Of Brothers that the Meta data is not working like it doesn’t familiar with this show
Can you check and advise
Aviv
It should work as long as you follow the file naming and file structure recommended in the solution post of this thread.
I moved your new problem post to a new thread so it wouldn’t muddy the waters for anyone who was following your other issue. :wink:
