There are some other issues being worked on but if you set your audio in Infuse to “Auto” and the Apple TV set to “Best Quality Available” as recommended in the support pages it should work like a charm.
I have the same problem since new tvOS realesed. Absolutely must be resolved as soon as possible! It’s a really priority to fix this bug! Personally I bought this app because was the solution to the pass through on Apple TV…and now it doesn’t work! A very fast update needs to be realesed
Same thing here. Since tvOS 11.3, the audio passthrough only provides a strong noise. And today I see Infuse got updated, making the passthrough feature disappear from the audio stream selection panel. …now it can only be found in the general Infuse settings.
I really hope you guys are not going to delete this feature completely.
FWIW, this topic is about the broken audio passthrough in tvOS 11.3. This is related to an Apple bug, and affects all apps that previously had passthrough enabled and working.
We’ve also been looking into a few reports of audio sync with 4K content that can appear in some cases, and we have a number of improvements in this area coming in 5.7 which is nearly completed. 5.7 will also feature our all-new native Plex integration which many have been looking forward to.
If you’d like to give the beta a try and see if it helps in your specific case, please drop me a PM and I’ll get you set up in TestFlight.
Thank you so much for the clarification, James. It‘s good to know the root cause of issue has already been identified. Appreciate your support very much.
