Hi guys!
After a long time using Infuse I’ve found a movie that doesn’t work. When I try to play it, it plays for one second and the the loading icon appears, then plays for another second and again the loading icon. Don’t know if there’s something in the mediainfo that could help to get the problem or if it’s a corrupt file.
Complete name : Los Idus de Marzo (2011) [BluRay 1080p x264 Dual Subs][GrupoHDS].mkv
Format : Matroska
Format version : Version 2
File size : 13.4 GiB
Duration : 1h 41mn
Overall bit rate : 19.0 Mbps
Encoded date : UTC 2012-07-17 21:23:41
Writing application : mkvmerge v5.0.1 ('Es ist Sommer') built on Oct 13 2011 12:47:36
Writing library : libebml v1.2.2 + libmatroska v1.3.0
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 41mn
Bit rate : 16.0 Mbps
Width : 1 920 pixels
Height : 800 pixels
Display aspect ratio : 2.40:1
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.434
Stream size : 11.0 GiB (82%)
Writing library : x264 core 116 r2057 0ba8a9c
Encoding settings : cabac=1 / ref=3 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=16 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=7 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=0 / bitrate=16000 / ratetol=1.0 / qcomp=0.65 / qpmin=0 / qpmax=40 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=50000 / vbv_bufsize=50000 / nal_hrd=none / ip_ratio=1.25 / pb_ratio=1.25 / aq=1:0.65
Language : English
Default : Yes
Forced : No
Audio #1
Format : DTS
Format/Info : Digital Theater Systems
Codec ID : A_DTS
Duration : 1h 41mn
Bit rate mode : Constant
Bit rate : 1 510 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossy
Delay relative to video : 21s 978ms
Stream size : 1.07 GiB (8%)
Title : DTS 5.1 @1,5 Mbps Castellano
Language : Spanish
Default : Yes
Forced : No
Audio #2
Format : DTS
Codec ID : A_DTS
Duration : 1h 41mn
Bit depth : 24 bits
Title : DTS 5.1 @1,5 Mbps Ingles
Language : English
Default : No
Forced : No
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Title : Subs. Forzados Castellano
Language : Spanish
Default : Yes
Forced : Yes
Text #2
Format : UTF-8
Title : Subs. Castellano
Language : Spanish
Default : No
Forced : No
Text #3
Format : UTF-8
Title : Subs Ingles
Language : English
Default : No
Forced : No
Menu
00:00:00.000 : en:00:00:00.000
00:06:55.665 : en:00:06:55.665
00:15:51.617 : en:00:15:51.617
00:20:50.249 : en:00:20:50.249
00:29:01.615 : en:00:29:01.615
00:38:01.321 : en:00:38:01.321
00:43:49.377 : en:00:43:49.377
00:49:07.194 : en:00:49:07.194
00:55:31.203 : en:00:55:31.203
01:04:49.886 : en:01:04:49.886
01:07:44.352 : en:01:07:44.352
01:11:45.676 : en:01:11:45.676
01:18:00.968 : en:01:18:00.968
01:23:37.846 : en:01:23:37.846
01:28:43.276 : en:01:28:43.276
01:31:24.979 : en:01:31:24.979
