Problem viewing photos
Hi All
I have successfully installed ATVFlash and use my ATV with an external drive as secondary backup.
The external drive has 2 partitions: 1 for movies and 1 for photos.
When I browse NitoTV/Files, I see the 2 partitions. When opening the photos one, I get an error message stating “The folder is empty or contains unsupported files”.
Any solution so I can play slideshows of my photos?
Note I have no issue watching movies from the 1st partition of this drive.
Photo photos will need to be ‘marked’ as photo folders.
  1. Highlight the folder that contains your photos in nitoTV.
  2. Press the right arrow (>>).
  3. Select the option to mark as photos
Selecting the photos folder will start a slideshow of the enclosed photos.
Note: While this solutions works, the best photo experience will be obtained by syncing the photos through iTunes and using the built in Photos menu.
Thanks, will give it a try tonight.
Hi there,
I have the same issue. Following your guidance my AppleTV restarts after selecting my photos folder.
Any ideas to get this issue solved?
