Problem returning to the interface after the movie ends
After the movie ended, it returned to the main screen.
Can it be set to return to the movie details page?
Because I want to rate the movie.
If you start playback from the video details page it should return you back to the details page after a video ends, which will allow you to rate the item. If you’re starting playback straight from the home screen then it may return you there after playback ends.
Thanks. I’ll try.
I tested the situation you described. If the movie hasn’t finished playing, clicking “Back” takes me to the details page. If I click “Back” after the movie has finished, it takes me to the details page of another movie.
If you have ‘Continuous Playback’ enabled in Infuse > Settings > Playback then Infuse may start playing the next movie after the first has finished. Exiting after the second movie has started would load the details page for that video.
Can you try disabling Continuous Playback to see if this helps?
