i got a tv show that is not reconized by infuse as well
how should i name it?
5156share.com.QiYeQR.SY.EP01.mkv
5156share.com.QiYeQR.SY.EP02.mkv
First, what show is this supposed to be?
What season?
it is a hong kong tv show called 企業強人
there is only one season with 25 episodes
This show isn’t entered in English in TMDB so you would have join their site and enter it there following their guidelines.
Now TMDB does come back with a show when using this in their search.
Is this the same show? It’s one season and 25 episodes.
If so you’d have to rename the episodes as follows replacing the “xx” with the correct episode number.
Big Biz Duel 2024 S01Exx.mkv
yeah this is the show. thanks.
thanks i will rename it as the format u suggested
