Problem Playing video with Infuse Pro 7 on TvOS 15
Hi, Infuse Pro 7 on TvOS 15, I getting stuck playing video too.
Can you describe what problem you’re having and with what type of video and which ATV?
Also is this the release version of tvOS 15 or the beta?
Hi, I keep update, but issue seems solved, after reset connection to my Synology. tvOS 15 is relaese version.
4 posts were merged into an existing topic: Stuttering playback after tvOS 15.0 update
Seems like we have three threads for the same (or at least similar) issue.
Definitely something broken with playback on tvOS 15 with Infuse 7.
Hopefully Infuse switching to the new player UI in 15 will fix it.
