Problem: Infuse 2.2.1 PRO - Connect to QNap NAS
Hi there,
I’am using Infuse Pro v2.2.1 and wanted to connect to my QNap NAS HS-210 - but somehow it does not work.
Settings:
Adress: 192.168.2.240
User: admin
Password: admin_password
After having the settings set, I can connect to my NAS - I also can see the folders. But if I select one folder an error occurs .
How to solve the problem?
Best regards,
Johannes
Did you check the permissions on the QNAP? Normally admin has always read/write permission but it may be good to check this.
I also have a QNAP and I can connect and play movies with no problem.
Also, please ensure you are running the latest 2.2.1 version as this includes a few fixes for streaming.
