Problem connecting to MacOS Big Sur
Have just upgraded to macOS Big Sur and now see the message ‘Indexing failed for (my) iMac’. I remember having to make some change many months ago for a similar issue, but don’t remember what I did exactly, something with SMB sharing. Has worked perfectly since then.
macOS Big Sur 11.0.1
Apple TV tvOS 14.2
Infuse Pro 6.5.4 (3348)
I see the same issue on iPhone and iPad apps, both 14.2.
Have you tried turning off sharing and then turning it back on in the Mac preferences?
Actually I didn’t, which of course I should have done first. Yes, works fine now!!
Betas are so much fun.
Isn’t Big Sur now a production release?
Probably, but even release versions can “act” like beta. :wink:
Rarely does the first public release of macOS not have issues. I generally don’t jump on the bandwagon until a .1 or .2
