PLEX share and Wake on LAN
Hello,
did anyone find out how to use WOL function for PLEX share. I found topis with same issue as I have : Wake on Lan with Plex
When I add MAC address to my PLEX share the WOL function doesnt work. Did anyone find any workaround how to getting it work?
Thank you
Do you have the WOL enabled on the server?
Yes, when im use different app which can send magic packet, the server always woke up without issue.
From reading the thread you referenced it doesn’t sound like it’s currently possible.
You may want to try adding an SMB share as discussed in that thread and see if that may wake things when the SMB share sends the WOL.
