1.)
I have set the Category „Comedy“ to all Movies within a Plex-Collection!
But the Collection don’t appear in the Genre „Thriller“…
What I do wrong? ?
2.)
Is it possible to use custom XML-Files in Plex-Content to override the Metadata etc.?
Can you provide a bit more info about the issue you are seeing? If you have all genres set to Comedy, then you won’t see these items in other genres. However, if you have recently made changes in Plex you will want to use the ‘Refresh’ option in Infuse to ensure these changes are reflected correctly in Infuse.
It may be possible to use XML files with Plex, but this would need to import the data in the XML files into Plex so Infuse can read it. Infuse is not able to use XML files for content stored in Plex.
I have set all Movies as Genre „Comedy“…
But then it appears only in the Library > Movies > Collections ?
But not in Genres > Comedy…
How can I import my XML-Files to Plex?
All my Movies have inside the folder an XML and Coverart, which normally is used in Infuse (with normal NFS Access)… But in Plex the XML etc is not getting recognized ?
Ok ?
It was just a thought as „Workaround“ to get my own Custom Collections in Infuse ??
But it’s not really a good way, if I can’t directly use all my XML and Coverart files.
But is it maybe soon possible to create own collections directly in Infuse? You say something, that this is based on the new Playlist-Feature?
