Plex Playlist Cover Art Location
I know Infuse can’t do Square Art for playlists yet, but I cannot locate where Infuse is getting the covers that it is using.
I’m using Plex to create playlists and I changed the “poster”, “square” and even “background” art in Plex options, but none of them changed Infuse’s playlist cover art. Where are those files located so that I can at change it?
If you are connected to a Plex server then all artwork would come from the Plex server itself. Infuse would not fetch any metadata and artwork of its own.
That makes sense, as all of the other artwork is synced (Movies, TV, Collections).
However it does not seem to be the case for the Playlists. Ideally it would use the square artwork, but none of the artwork options (Poster, background and square) in Plex seem to show in Infuse. I could be missing something though.
