Plex multiple 4K versions. How to tell them apart?
My Plex media often has separate DV profile 5 and HDR versions of the same film/TV show because some of my devices cannot display Profile 5 correctly. Is there a way to display whether the version is SDR, HDR, or DV in this “select version” window? It is impossible to tell which version is which when both are 4K and the same bit rate.
