PLEX + MKV + .SRT???
Well,that's it, there is anyway to make show up the srt subtitles.The are in the same folder, with the same name that the proper mkv.There-s no support, or need some extra Plex plugin?
Thanks!!!!
I used ffmpegX to burn .srt subtitle files into .avi files without re-encoding. It will probably work with .mkv files. It's fast and easy.
Thx for the tip!
I´m using it right now,  i select the video, in the filter tab load the .srt en select burn to the type.But then i need to hit Encode.Even if in the video tab i dismark encode video.
Am i doing it well?
Well, in avi it really works, in a few minutes its done, but with mkv theres no way.
