I never see Collections for my other 2 Libraries from Plex.
I have 3 libraries. Movies, TV Shows and Anime.
Firstly, Infuse joins the TV Show and Anime library together and there seems to be no way for me to separate them.
Secondly, there are no collections showing up for TV Shows despite the fact that through PMM I have a lot of collections for TV Shows and Anime in Plex.
Infuse will group content from multiple sources together in the Library. If you prefer to browse them separately, you can do so via a direct Plex favorite. You can then also exclude content from the Library by adjusting the Settings > Library page.
Bit confused here, on tvOS I have the library section show “Movies” “Anime” “TVShows” and “Other” all 4 coming from Plex which I have checked on. Could you tell me what you meant by “direct plex favorite”?
and thanks! did not know collections are limited on that aspect.
