Plex & Infuse 6 default favorites
Hi Guys,
Loving Infuse and Plex integration, great work.
I used to have infuse read the files from my synology server directly, but have recently started running a plex server.
I noticed that I had multiple of the default ‘movies’ ‘TV’ ‘Others’ favourite icons after I updated to v6.
I removed these and then added the favorites from my plex share. However these are now just shown with the orange star icon. How do I get infuse to scan and display the default favorites (blue movie icon and pink/purple tv icon)? I don’t use the ’library’ feature as have multiple plex libraries with duplicate movies.
Hope you can help!
Many thanks.
Your best option may be to hide the orange favorites, and re-add the Library favorites (which will give you the colored icons).
More info on adding and hiding favorites can be found here.
