Plex hubs above “Recently Added” leak into Infuse’s Recently Added row
Infuse version 8.5.6 (8.5.5763), Plex Media Server 1.43.4.10903
If any hub sits above “Recently Added in Movies” on my Plex home screen, Infuse puts that hub’s items at the front of its Recently Added row. The real recently added movies only show up after them.
I first noticed it with Plex’s built-in Seasonal Movies hub, which this month is “Oh, The Horror!”. The hub has 345 movies. Infuse requests count=20, so Plex returns the first 20 of them, and those 20 are what show up at the start of Recently Added. The seasonal hub doesn’t get a row of its own in Infuse. Its items just end up in Recently Added, and they change on every refresh because Plex shuffles that hub.
It isn’t specific to the seasonal hub. When I turned the seasonal hub off and promoted a regular collection (“Oscars Winners 2026”, 14 movies) in the same spot, Recently Added started with those 14 movies instead. That collection did get its own row, and the row was fine.
Order is what triggers it. Hubs below Recently Added never leak in, my Popular Movies collection has always sat there without a problem. When I moved the Oscars collection below Recently Added in Manage Recommendations, Infuse showed Recently Added correctly. Plex Web is fine either way.
The Plex side checks out. Infuse requests /hubs/promoted?count=20&excludeContinueWatching=1&contentDirectoryID=1, and with the seasonal hub on top my server returns:
movie.curated.1.1                  "Oh, The Horror!"          size=20
movie.recentlyadded.1              "Recently Added in Movies" size=20
custom.collection.1.82118.82118    "Popular Movies"           size=20
Every hub has the right items and a matching hubKey, and none of the horror movies are in the Recently Added hub. My server logs show Infuse never requests Recently Added or the seasonal hub separately, so the mixing has to happen when it parses this response. It looks like the item list doesn’t get cleared between hubs until Infuse reaches the first hub it displays.
To reproduce:
  1. In Plex, turn on Seasonal Movies for Home, or promote any collection to Home.
  2. In Manage Recommendations, put it above “Recently Added in Movies”.
  3. Refresh the Infuse home screen. Recently Added now starts with that hub’s items.
For now I’ve moved things around to get around it, but I’d really like to put the seasonal row back on top.
Plex Web, with “Oh, The Horror!” above Recently Added.
Infuse. The Recently Added row is scrolled right to where the leaked horror movies (orange) end and the real recently added movies (blue) begin.
Good write-up, much better than the one I posted in this thread. I think I disagree with one point, though:
Here’s what I noticed:
So, in my experience, if you scroll far enough to the right, you’ll also see movies from collections pinned below Recently Added. That’s why I always end up disabling that row and pinning the “real” Recently Added collection from Plex instead. Both can be pinned separately, at least in direct mode.
Here’s how it works for me:
I have a library called Movies in Plex. When I first set up the Infuse home screen, there’s a default row called “Recently Added in Movies”. This is the problematic one that mixes in items from pinned Plex collections, resulting in duplicates and incorrect ordering.
I have to hide that row and pin “Recently Added Movies” (without the “in”) instead. That’s the actual Recently Added collection from Plex, which displays the movies in the correct order without any duplicates.
The fact that Infuse exposes two almost identically named lists, only one of which works correctly, is unnecessarily confusing, as I mentioned in the thread I linked above. Unfortunately, that thread never received a response, so I hope this one gets more attention.
I also noticed that the Recently Added Movies collection is immune to this issue. However, it’s plagued by another one: it shows recently added movies from all of my libraries of type “movie.” This would be expected behavior if I had “Merge Recently Added Items” enabled in Plex, but I don’t. So in my experience, Recently Added in Movies better reflects Plex’s Recently Added in Movies row, except in the situation where there’s a collection pinned above it in Plex.
I’m not sure if this is somehow specific to my setup, but I just tried adding the default Recently Added row back and, sure enough, after the first 40 Recently Added items, I see items from other collections, in the same order they’re pinned in my Plex settings. You do have to scroll quite a bit to get there, so it probably doesn’t matter much, but I bet you’ll find the first item from your second collection at position 41.
I see! I don’t have multiple libraries of the same type, but I just captured Infuse’s network traffic and noticed something that might be relevant: Infuse sends a request to Plex at /:/prefs/get?id=MergedRecentlyAdded, which returns http 404. So it looks like Infuse is trying to check whether the Merge Recently Added preference is enabled, but the request fails, and perhaps Infuse assumes it’s enabled by default.
The endpoint itself is valid, but I checked the X-Plex-Token header, and it appears to be using the managed user’s token rather than the server administrator’s. That could explain why it can’t retrieve the preference. I also tested the same endpoint manually with my admin token, and it returned the correct value.
