Plex Filtering and Sorting in Direct Mode
While it’s fantastic that after all these years the multiple filters from library is finally getting done, using Library mode with a Plex share is outdated in favor of Direct Mode.
We need the ability to properly filter our content. I’ve done extensive research into the Plex API to find out if this is possible and apparently it’s extremely simple via XML calls. Of course, as a developer I know that integrating these things into an existing codebase is perhaps a bit more complex but this is the bare minimum we need.
  • Filter by Genre
  • Filter by Unwatched
  • Respect the “do not show collections” when sorting via Plays (currently the closest to Unwatched, though it’s not nearly the same). This used to respect the Plex setting but for the past x number of versions it does not.
I think most users who have Plex shares are doing so via Direct Mode and these are critical features to display your libraries. I believe there is very little interest in using Library mode, especially when Infuse is grouping all your movies together and all your tv shows together instead of actually showing the individual Plex libraries (or at least an option to do so). Plus, why would we want to store all the metadata that our Plex server already have in place? Direct mode is fantastic and very reliable but it’s impossible to continue using the software when the basic sorting and filtering is being ignored.
