Plex fetching errors
[Req#4fea] X-Plex-Container-Size header exceeds limit 1000. This will fail with status code 400 in the future.
. I am currrently getting this error causing sync to be wrong
Which version of Infuse are you using?
Can you send in a report and post the code here?
I wasv able to fix this by blowing up my plex docker container and resync again
