Plex connection
Hello, on main Infuse page i can see promoted features including Plex:
"Infuse 6 - An elegant video player | Firecore
UPnP & DLNA
Connect with UPnP/DLNA apps like Plex, Kodi (XBMC), Serviio, and others to browse, stream, and download videos."
But when i try to connect to Plex server via internet i get login/password incorrect error (works fine via browser etc).
Is it only me or it is known bug?
Thanks.
In order to connect with Plex you will want to ensure DLNA is enabled as described here.
Yes, problem starts when connection is over internet, not lan. I guess it is not supported, nvm.
Ah, got it. Yeah, DLNA is local only.
There has been some interest in developing a deeper integration with Plex, and this is something we will likely look into for a future update.
