Quick question. I have some 4K movies in plex and make use of the multiple versions feature grouping it with a 1080p version of the same film. In Infuse this shows up as a “2” and allows me to select which version to play initially. This is great! However if I want to switch to the other resolution I don’t see a way to do so and I am never asked again which version to play after the initial viewing. Am I missing a way to do this?
If I recall correctly, long pressing the play button will prompt you with a version selector
