Please Help
I’ve been watching my divx and iso files in xbmc coming from my terabyte hd and its starting to stick every now and then, like a very very quick pause, then it plays fine. Does this about 10 times during any movie. Im wondering if it has anything to do with the cache. I have messed with that setting and I dont know what it should be set to, can someone explain that? Any help would be greatly appreciated! :slight_smile:
If you are in XBMC, you want to go to Settings > Videos > Player > Cache and change the Hard Disk cache and see if that helps.
I know…just didnt know whats the optimal setting. ill mess around with it in the mean time…thanx
Ya, sorry I didn’t really answer your question. I think if you just keep going up in cache size, it should fix the issue.
