Playlist for Seasons
Is there a way to add a season to playlist not only the episode. As when I add a show to playlist it only adds that episode and not the season of the show
If you browse the share (not in the library) where you see the poster for each season you can long press on the season poster and get the menu to add that season to a playlist.
Ok I long press on the cover for the show. But then it adds every single episode instead of just the poster cover then showing all seasons inside when you press the poster cover. Not sure if explaining correctly,
IE: plex shows poster you press it then once you do that it shows all seasons. And you can set the playlist to do that.
That’s what I am looking for it to do thanks
Sorry, I don’t use plex. I did test it in just Infuse and it adds just the season when you long press on the season poster when browsing in the favorite.
Ok but when I do that it adds every single episode to your playlist. So if you have numerous shows to add. It’s endless. Rather than just having a cover post for each show.
Understand ?
Have you tried a collection instead of a playlist?
Haven’t tried Collection, but can’t seem to find how to add items to it.
It appears that Infuse can’t manage collections with Plex however, collections can be created using the web app for those servers.
