Playlist Filename
Hi could someone please tell me what the file name of the user created playlist is? I’ve spent a lot of time creating playlists want to make a copy of this incase things go amiss so I don’t have to recreated it. Thank you
Unfortunately, playlists and other library data cannot be exported from Infuse at this time.
However, if you have iCloud Sync enabled then this info will be saved to iCloud and will be available if you add a new device, or reinstall the app.
