Playlist Bug
If you make your own playlist of movies in Infuse and then change the location of the movie on the computer. Then the playlist in Infuse is NOT updated with the new location and cant play the file.
This is a limitation of how playlists work at this time, as Infuse is not able to know where the videos were moved to.
Trying to guess this could lead to issues, as you could have a video named video1.mp4 in one folder and a video with the same name in another folder. Showing these both in a playlist would not be ideal.
Hi!
This maybe would be solved with Icloud.? The movies in the playlist should be able to be kept track of in the same way that Infuse keeps track of ordinary movies that have been moved around on the computer. Just a thought.
