Player stops after each single song
when starting my playlist in Computer -media library -music it stops after playing a single song without continuing with the next one.
Any clues how to get this working as it should do?
Thanks in advance, Kai
put the songs in a folder and create a playlist by holding the middle-button!
If you start a song with the OK button then it stops after that song. However I find that if I start by hitting the Play button then it works hrough all songs in the current folder.
Hi itimpi,
I experienced the same here. It works correctly now after rebuilding the iTunes library and using the aTV RC1. Hope it stays this way.
Kai
