remo
December 3, 2025, 8:46pm
1
Hello.
For about last 2-3 versions of Infuse, I have sync issues across iOS and tvOS.
It does not happen for fully watched episodes and movies - it’s out of sync for started, not yet finished, episodes and movies.
Marking as fully watched manually, either on iOS or tvOS, won’t sync to each device.
What can I do?
james
December 3, 2025, 8:47pm
2
Are you using Trakt by chance?
remo
December 3, 2025, 8:56pm
3
Yes. TRAKT is activated on all devices. It worked in the past without any issues.
james
December 3, 2025, 9:11pm
4
Thanks for confirming that.
In that case, this is likely related to a recent change with the Trakt service which we are working to address. You can follow this thread for updates.
Quick update.
This issue is related to some recent changes in the Trakt API; specifically, in the methods we use to report playback progress. The pause method has been removed and stop now has a minimum progress requirement.
We have implemented a set of fixes which are currently undergoing internal testing.
Thanks for your patience here.
