I often increase the playback speed, usually when I watch Anime, because of the amout of episodes.
I’ve noticed that the playback is not smooth anymore, when increasing the speed.
It seems that Infuse somehow catching up the video, I can’t really explain it.
Am I the only one? Can someone try that too? @NC_Bullseye@james
I wonder if the streaming cache setting under playback in the Infuse setting would make a difference? If set to auto and you pause for a little bit to let it build a buffer before playing back at a higher speed?
It is set to auto and waiting to buffer makes no difference.
I’ve tried a little bit and I’ve noticed that the smaller the increase is, the more you can see the behavior, I am trying to upload a video of 1,05 playback speed:
