Playback issues with HEVC on ATV4
I wanted to watch a part of a course I am following on my Apple TV and when I started it the video hung, audio simply went on. I pause, move the progress cursor up and down and see the thumbnail update. I decide to play again somewhere and… Black image, I do hear sound. Interesting. So I go to my computer, fire up Infuse, play the same file, no problem. Hmmm.
VLC on computer: no problem.
I download Infuse 7 from the App Store so no beta version, and video hang. Download VLC from the App Store, and run the file… Also a hang.
So, video handling on Apple TV is different than the computer?
Also, is it possible to have both Infuse The Beta and Infuse The AppStore on the Apple TV? Installing them overwrit the other one. Makes it hard to A <> B problems.
My Apple TV is a HD one, not the 4K. And my computer is running Monterey., Both are running the latest OS versions applicable to them.
I can get upload the file to you for playing around with it, but I do need the dropbox address. I don’t remember that. In fact I’m not even sure it is dropbox…
P.S. I do see some weird artifacts at the start of the file (the problem starts basically within the first 5 seconds), but still Monterey has no probems (apart from the artifact at the start), and Apple TV decides to keep the video frozen.
It may help to run it through mediainfo and post the results here.
General
Complete name : /Volumes/Entertainment Rest/Courses/Programming The Style Of 80s Studio Drummers (Henning Pauly)/02. Sounds.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (mp42/iso2/mp41)
File size : 306 MiB
Duration : 20 min 35 s
Overall bit rate : 2 078 kb/s
Encoded date : UTC 2022-03-30 12:50:56
Tagged date : UTC 2022-03-30 12:50:56
Writing application : HandBrake 1.5.1 2022011000
Video
Format : HEVC
Format profile : Main 10@L4@Main
Codec ID : hvc1
Codec ID/Info : High Efficiency Video Coding
Bit rate : 1 752 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.034
Stream size : 258 MiB (84%)
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Codec configuration box : hvcC
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Format settings : Joint stereo / MS Stereo
Codec ID : mp4a-6B
Source duration : 20 min 35 s
Bit rate mode : Constant
Bit rate : 320 kb/s
Channel(s) : 2 channels
Sampling rate : 48.0 kHz
Compression mode : Lossy
Stream size : 47.1 MiB (15%)
Source stream size : 47.1 MiB (15%)
Title : Stereo
Writing library : LAME3.100UUUUUUUUUU
Default : Yes
Alternate group : 1
mdhd_Duration : 1235257
Thanks for that! Maybe @james will be able to look at this and see if there’s any obvious gotchas.
The ATV4 has limited support for HEVC, and these need to be decoded using the less-efficient SW decoding method.
The newer ATV4K models include HW decoding support for HEVC, which will probably fix most issues related to HEVC playback you are seeing.
Ah! Ok… A reason to get the new one, lol
Thanks for the clarification
