I wouldn’t say tvOS allowed passthrough. What happened is some apps exploited a hole in the tvOS audio pipeline that allowed apps to use IEC 61937 to hide some bitstreams in what looked like a simple PCM stream. In short, the apps were telling tvOS they were sending PCM but were sending PCM with a bitstream. tvOS apparently didn’t check and thats how the limited bitstreams made their way to the receiver. The exploit didn’t passthrough any lossless formats. The exploit was fixed in tvOS 11.3 beta when it was discovered the exploit broke audio routing and multi-room audio. The exploit also broke other existing features as well as future features in the pipeline including 2-3 features that were recently added.
Rivulet and Plozz have removed height from lossless formats in their latest updates: Reddit
Native Player devs seem confident that their implementation is on the up and up.
FYI the test flight builds have kept it in
Reference? Which app? Not Rivulet. It tracks build.
124 on testflight truehd > flac and deletes heights like Infuse.
The public apple app store version continues to do truehd>pcm>apac because the build is older and hasn’t trickled through to public.
- You can download an old build from testflight butnyoull have less than 3mo
- You can before it updates further, download from public and turn off appletv app updates and hope you get more time than that.
- Hope James can figure out a way to make legitimate and permanant support because the truehd>pcm>apac is very clever.
Sodalite TestFlight still has it.
