Hello,
My pip ability has vanished. The option is the whole reason I BOUGHT the app. It is no longer present.Any others have this issue? Any help is greatly appreciated!
Hello,
Do you know what type of video you are playing?
Since PiP is an Apple-designed feature, it will only support h.264 and h.265 based videos.
If you’re using an iPad, you can use split-screen for all video types.
Iso and mp4’s. Does it support those?
