It seems that if I enable PiP while streaming a video from a webdav source, the progress bar repeatedly increases and then the stream stops after a few minutes. Are there any settings I can adjust to enable streaming in PiP?
If this happens again, could you send in a quick note from your device so we can take a deeper look into what may be going on here?
More info on sending in reports from your device can be found here.
Done! Thanks!
