Pip button is not clickable by using apple remote
But i am using a third party ir remote it is work.
Problem happen when latest update install in apple tv
Infuse version 6.5.4(3348)
Are you saying you were just unable to select it or it doesn’t show up at all? The latest version ass to have a deliberate swipe up to select the button
I am unable to swipe in apple remote and same apple Tv Remote App Not Work
One thing to try would be a longer (and maybe slower) up swipe motion for both the Remote App and Siri remote.
The quick(er) swipe behavior we had in 6.5.3 was causing issues for some users where PiP would accidentally be enabled.
Thank James Long Swipe Working Great.
